Menvier Sd1- Dialler
Guest opcenterclancy
Hello,
I have bought a SD1+ Menvier to connect to my old 5494 Scantronic alarm, is there somebody to explain to me how to connect it?
Is it possible to connect the dialer instead of the outside bell or internal speakerphone?
Thank you in advance for your help.
Yes you're right it's not the speakerphone but the internal loudspeaker
Hello,
Hi, what area are you in? I'm sure there is a professional member here in your area who would be able to connect this up for you.
Hello and welcome, yes you can disconnect the internal speaker and the external siren and just have the SD1, I would not recommend the siren be diss'd. The SD1 needs positive and negative and at least one trigger, you can take this from the siren trigger.
