Guest Guest_GEOFF_* Posted February 23, 2006 Posted February 23, 2006 Hi I have a faulty PIR on my Optima 2 plus, can anyone recommend a PIR that is compatible - the existing sensor /s are ROKONET
Guest ALSEC Posted February 23, 2006 Posted February 23, 2006 HiI have a faulty PIR on my Optima 2 plus, can anyone recommend a PIR that is compatible - the existing sensor /s are ROKONET What is your location - I'm sure someone on here can help you out?
Guest Guest Posted February 24, 2006 Posted February 24, 2006 My location is Cumbria - the reason I asked for a compatible PIR was that the system is 10 to 12 years old and I didn't think I'd be able to get one to match - can you recommend one that I should buy to replace it, I've already had the existing one off and swapped it with one in a different zone to prove that the PIR was faulty, my main concern with getting a replacement was would the wiring be the same, if so it would be a simple straight swap.
