Aritech
Guest Phild
does anyone know the correct way to wire aritech cd72 to a lyntech SAB.
Thanks
Phil
Thanks
Phil
bell + output in panel to h+ on bell
bell - output in panel to trig on bell
aux - in panel to h- on bell
loop of bell trigger for strobe( as strobe not a requirement)
right terminal of tamper in panel to tamper return in bell but connect a 4k7 resistor to TR first. (TR must be a neg return though)
This is the norm for none aritech bells.
Chris
Trade Member
Chris
Thanks Chris
I think I've got it about the same. There is an internal and external bell+ and bell-
ext bell + to h+
ext bell - to h-
int bell - to trig
int bell - to strobe
tamper return to 4K7 + terminal in panel as above.
Regards
Phil
Guest Phild
Chris
What about the left tamper terminal - you've only mentioned 1 onto the bellbox? The sounder goes off when I attach the tr-. aritech say I need a relay to sort this out?
