Guest n1g3 Posted February 25, 2006 Posted February 25, 2006 Hi I have just had the above given but have no instructions etc.... any help would be very gratefully recieved. Nigel
Monteey Posted February 25, 2006 Posted February 25, 2006 ?????? Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
FASTCAR Posted February 25, 2006 Posted February 25, 2006 I think it was a cctv system sold by A1 years ago..I think ADE took it off their hands. PM me. Regards.
Guest Duxbury Posted December 14, 2006 Posted December 14, 2006 In reference to your enquiry I have just found a installtion and instruction manual for the ATC 7 (although it has ATC 4 on the cover, I still have the unit, ATC 7). Have saved a pdf file. See attachment. Hope its not too late. Regards. Campa1gn_CCTV_ATC4_7.pdf
samchloe Posted August 15, 2007 Posted August 15, 2007 In reference to your enquiry I have just found a installtion and instruction manual for the ATC 7 (although it has ATC 4 on the cover, I still have the unit, ATC 7). Have saved a pdf file. See attachment. Hope its not too late.Regards.
samchloe Posted August 15, 2007 Posted August 15, 2007 I too am trying to access the instructions for the ATC 7. Unfortunately the pdf file is damaged. Can you or anyone please post / send an undamaged copy. Thanks
amateurandy Posted August 15, 2007 Posted August 15, 2007 I too am trying to access the instructions for the ATC 7. Unfortunately the pdf file is damaged. Can you or anyone please post / send an undamaged copy.Thanks The file is perfectly fine, I just accessed it via the post. Probably something wrong with the installation of Acrobat reader on your PC.
samchloe Posted August 16, 2007 Posted August 16, 2007 The file is perfectly fine, I just accessed it via the post.Probably something wrong with the installation of Acrobat reader on your PC. Thanks - I have just tried it again and managed to successfully download it.
