Guest spirochete Posted February 25, 2006 Posted February 25, 2006 Ongoing story of the 'relocation' of the 4110 panel (from last week)......... All in and OK but could anyone help / point me at the *code for D/K ........ I'm assuming that the panel can accommodate D/K on the PIRs....BUT the install info I was left for this panel is only about two thirds complete, (& yes, I do have the Eng code / reset codes). Also, if any kind soul can fill in the 'gaps' in the literature I would be interested to know what the function of the following are (if anything) * 03 /04 / 06 / 07 / 12 / 15 /16 / 17/ 18 / 19 / 20 / 23 / 24 /26 & 28 . I assume this lot comprised 'page 1' for which I only have hand written notes from the previous owner / installer ........the rest of it [29 upwards] I have on the original sheets. (First sheet must have taken quite a bashing over the years ) Anything you could tell me to help narrow things down a bit would be greatly appreciated. (PM ?) (Trial and error /process of elimination gets there but is a pain in the b*tt !) Hope I'm not breaking /bending the rules with this request ...... Kind Regards, Spiro'
j.paul Posted February 25, 2006 Posted February 25, 2006 All in and OK but could anyone help / point me at the *code for D/K ....... "option 20" in zone programming There are no stupid questions, but there are a LOT of inquisitive idiots.
Guest spirochete Posted February 25, 2006 Posted February 25, 2006 Thanks, I'll get to it tmrw. Out of interest ( same issue) how effective are so called 'pet-proof' PIRs in your opinion? (We've got 3 mogs who have an uncanny ability to hide when its time to kick 'em out and it wouldn't be the 1st time one of the b*ggers has set the system off!) If they really discriminate to a worthwhile degree then changing over the sensors might be on the cards........ ?? Spiro'
j.paul Posted February 25, 2006 Posted February 25, 2006 Thanks, I'll get to it tmrw.Out of interest ( same issue) how effective are so called 'pet-proof' PIRs in your opinion? (We've got 3 mogs who have an uncanny ability to hide when its time to kick 'em out and it wouldn't be the 1st time one of the b*ggers has set the system off!) If they really discriminate to a worthwhile degree then changing over the sensors might be on the cards........ ?? Spiro' Do a quick search on "Pet immune Detectors", there are loads of post on the subject There are no stupid questions, but there are a LOT of inquisitive idiots.
Guest spirochete Posted February 25, 2006 Posted February 25, 2006 Right! Point taken - (I should have had a 'dig' first.) Clearly an emotive topic........question on 'pet-proof' closed! Spiro'
