Ade Viper Shock Sensor
Guest john mck
One thing that baffled me when first fitting the new vipers, being the GL and the GLX. Sometimes the latch facility worked and then on other version it doe'nt. After a lot of playing around. I now know that the GL I think the ONE WITHOUT the dip switches needs to have the link cut 2nd along. Small snips needed. This will allow the set + to latch and reset nicely. As for the GLX this seems to work ok without moving the dip switches. Although its set up for double knock if you leave the dip switches as they are.
anyway hope this helps anyone.
