Vista 4110 Uxm With 6127 Keypad
Guest Guest_Andy_*
Guest Guest_Andy_*
Hi
I have a Vista 4110 UXM with 6127 keypad that was linked to //.National Installer.// when we moved in to the house but has since been disconected. The alarm is locked and shows the CE 06 86750 not ready code and won't allow me to reset or override. As we are no longer connected to //.National Installer.// I would like to be asle to reactivate the system and have it as a stand alone system.
How do i reset the system and allow it to work again???
I know its and old system but its better than nothing
Hello and welcome Andy
The 4110 is a good panel and should have plenty of life left in it. However to clear the engineer message you do require the services of an engineer whom can then programme it as bells only and customer reset, post your location and I am sure someone will be able to assist further.
Hi
Thanks for the very swift reply:
My location is North london should anyone out there be able to help
Thanks for the swift reply location is North London
Hi
You can also call //.National Installer.// out to make your system bells only for you, they'll also give you a full demo if required. Bet it used to be a Protection One system.
Wares were a fairly large co covering wakefield and surrounding area.
They installed a lot of vista's over the years, they were swallowed by Hex some years ago now.
Regards
Bellman
In London there were a lot of companies installing Ademco 4110's not just the Nationals.
