Guest deefadog Posted February 28, 2006 Share Posted February 28, 2006 micromark to modulator - this is the 4 din cable which goes to the scart plug which is moulded on ccd cam to modulator - this is a single phono cable, going to a scart adaptor which has video input (phono connection) 2 x audio input (phono connection) (not used and a svhs input (not used)- on the scart adaptor is a selector switch - cvbs & y/s - i can only get a pic on the cvbs position. inputs on modulator - scart only + Coax for tv arieal (not used) Not sure if it makes a difference but one scart adaptor used with the ccd only has 7 pins out put - top left there are 3, furthest pin right and 3 on the bottom row one in from the right across: basic diagram - I = pin - = no pin III------I ------III- Link to comment Share on other sites More sharing options...
Rich Posted February 28, 2006 Share Posted February 28, 2006 http://www.thesecurityinstaller.co.uk/scart.shtml It may be that the scart adapter you are using is for outputs, and the fact that it works with your TV direct is because your TV scart has a loop through. I'd suggest trying another scart adapter. Link to comment Share on other sites More sharing options...
Guest deefadog Posted February 28, 2006 Share Posted February 28, 2006 Thanks Rich, i'll get another one! Another question, if i got a duel scart connector, so i could plug the ccd scart and the microvision scart into the same modulator, would it work? or would the both signal inerfere with each other? Thanks again! Link to comment Share on other sites More sharing options...
Rich Posted February 28, 2006 Share Posted February 28, 2006 Thanks Rich, i'll get another one!Another question, if i got a duel scart connector, so i could plug the ccd scart and the microvision scart into the same modulator, would it work? or would the both signal inerfere with each other? Thanks again! Both signals would sit on top of each other, you would have to get 2 modulators with different channels. Link to comment Share on other sites More sharing options...
Guest deefadog Posted February 28, 2006 Share Posted February 28, 2006 Thanks Rich, that makes alot of sense! Rf concepts do the multi channel ones i think i'll have a look on there! Link to comment Share on other sites More sharing options...
WatchdogSecurity Posted February 28, 2006 Share Posted February 28, 2006 Thanks Rich, that makes alot of sense!Rf concepts do the multi channel ones i think i'll have a look on there! I use Philex RF modulators, offers multi chanels and choice of scart in or phono in, there well made as well. Watchdog Security (Manchester) Link to comment Share on other sites More sharing options...
Guest deefadog Posted March 1, 2006 Share Posted March 1, 2006 Thanks do you have a link? I found this - http://www.globalsources.com/gsol/I/Four-W.../1000858112.htm But i think you might have to manually switch this, it would be good to have one rf modulator where you can have 4 inputs and set each channel for ech input. Can you get something like this? or would i have to get 4 seperate modulators? Link to comment Share on other sites More sharing options...
WatchdogSecurity Posted March 1, 2006 Share Posted March 1, 2006 Thanks do you have a link?I found this - http://www.globalsources.com/gsol/I/Four-W.../1000858112.htm But i think you might have to manually switch this, it would be good to have one rf modulator where you can have 4 inputs and set each channel for ech input. Can you get something like this? or would i have to get 4 seperate modulators? Your probably looking at 4 RF mods, unless they do a commercial one: Link here: HERE Watchdog Security (Manchester) Link to comment Share on other sites More sharing options...
Guest deefadog Posted March 1, 2006 Share Posted March 1, 2006 Thanks, hopefully i can find a supplier in my area! Take care Link to comment Share on other sites More sharing options...
baywatch Posted March 1, 2006 Share Posted March 1, 2006 System Q do a 4 camera controller with built in modulator. The cameras can then be selected by a wireless keyfob from anywhere in the property or controlled byalarm inputs. Link to comment Share on other sites More sharing options...
