Battery Orientation In Galaxy 2-12
Guest barticasun
Guest barticasun
Hi Guys
I've had a galaxy 2-12 installed to to fit it within the limited airing cupboard space it was installed sideways ie 90 degree's around the clock face.
This mean instead of being horzontal the backup battery it seated vertical.
Battery used is power sonic ps-1270
Being sealed do you see this as an issue?
cheers
Simon
I would be wary of the temperatures in an airing cupboard (as loft's) and would look for somewhere more suitable as mentioned batteries can hurt.
I spend 1 hour righting a badly installed panel once which cracked the tiles in the downstairs toilet when I took the damn lid off!!!
Guest barticasun
cheers guys much appreciated.
Yes the location is not ideal.
Thanks again.
Simon
