New House, Old Alarm, No Code...
Guest johnauger
Guest johnauger
Hi there, hoping someone may be able to help me out. I've moved into a property that has a full //.National Installer.// security system already installed. However the previous owners didn't use the alarm, and as such didn't leave a code. The contract with //.National Installer.// expired years ago, and they have no record of the alarm on their system. It is an "//.National Installer.// Series 3200 Plus". Obviously, I'm keen to get it reset asap, so it will be in a working state, but have no code or anything else, other than a manual, which again isn't much help without a code.
Anyone got any advice?
Many thanks
john
Get an Engineer in to reinstate the system / replace the batteries and service/setup the system for you.
or ring //.National Installer.//..
Hes already rung them!
and wants the work done free i take it.......
Good Morning John, as mentioned ring //.National Installer.// and explain that you wish to re- enable your system and take out a maintenance contract.
Guest johnauger
Eng,
Contrary to your assumption, I was at no point thinking I'd be getting the "work done free". I totally realise this is a professional job, and was only asking for advice...
But thanks for your two cents worth anyway.
For the record, I did ring //.National Installer.// and they were less than helpful... But I'll keep trying
Ta
Guest Peter James
John post your general location, there will be a somone on here who can help.
Pete
the //.National Installer.// panel is not vital so if you think they have given you the 'bums rush' other companies will hapily replace the controls.
