Alarm Wiring In The Kitchen
Guest Gti Jazz Blue
Guest Gti Jazz Blue
So what is the situation with alarm cabling in a kitchen ? Notifiable under Part-P or not ?
If you read the documents (had a bored moment) I can't see that Alarm cabling is allowed in a kitchen, with out notification.
So how are the pros handling this with new installs ?
no,unless the spur's in there
Guest Gti Jazz Blue
OK thanks, I couldn't see an opt out for LV signalling equipment in a special area i.e. Kitchen. That could be tricky as it would stop you running alarm, phone, TV or door bell cabling.
Don't quote me, but i'm sure I read somewhere that phone cabling is not allowed in the special area (kitchen and bathrooms), but like I said I'm not 100%
Trade Member
Contact your council building control people, they should be able to tell you if it's notifiable.
I can't remember what happened in the end but as SELV is <50V and phone cabling can be >50V it comes under part p. They may have changed this, but I'm not 100% sure either!
Guest Cerberus NI
Aren't I glad I live in this part of UK!
its short but it the full answer
Telecom
The kitchen is not a special area as defined by 7671,
But it is according to part p, which is what the thread was about.
