Alarm Wiring In The Kitchen
Guest Gti Jazz Blue
Contact your council building control people, they should be able to tell you if it's notifiable.
Should is the right word to use :unsure:
But it is according to part p, which is what the thread was about.
banghead any new work on ELV fixed electrical wiring for communication and information technology (IT), signalling, control and the like is
Guest Gti Jazz Blue
Thank you, so I guess the phone and CAT5 network point in the ensuite isn't allowed then :(
Depends if its contains a bath or a shower, if so its a SPECIAL LOCATION
So that also means that an Alarm install in a detached garage is notifiable work,
Low voltage no, mains wiring depends what your doing but usually yes
Guest Gti Jazz Blue
Right so an alarm could be installed as long as it wasn't wired off a spur unit, so one wired off a plugtop would be fine then. I suppose it is that or I just get a sparky in, that is a member of a scheme to install the spur side.
yes under part p, no under bs 4737, en50131 / pd 6662 maybe / maybe not
