Control Panel Sounder Problem
Guest YorkieJohn
Guest YorkieJohn
Sometimes the sounder in our alarm control panel goes off when the alarm is not set and the 24hr lights up, on taking the cover off and checking everything nothing seems to be faulty or wrong with it. What can be causing this ? The external bell box does not ring as I say it occurs when the alarm is not set and we are in the house. Any help would be appreciated. It is a wired diy alarm. The alarm has been fitted about 10 years and this problem has just started occuring
You have a tamper fault, if you can tell us what panel you have we may be able to help further.
Guest YorkieJohn
It is an AJ600 Control Panel
Probably the battery then. I'm assuming it hasn't been touched since it was installed? It is possible that the lack of a decent battery could have damaged the system, a service would confirm or deny this.
