Guest stevey Posted March 8, 2006 Share Posted March 8, 2006 Whats the best 1/2" CCD Day Night Camera to be used with near 730nm infrared light at night? I know that the samsung 1/3" with manual IR cut filter is the best in the 1/3" CCD range, but anything equivilent in the 1/2" range. Steve Link to comment Share on other sites More sharing options...
WatchdogSecurity Posted March 8, 2006 Share Posted March 8, 2006 Whats the best 1/2" CCD Day Night Camera to be used with near 730nm infrared light at night?I know that the samsung 1/3" with manual IR cut filter is the best in the 1/3" CCD range, but anything equivilent in the 1/2" range. Steve Baxall CDSP9772, nice camera but very pricey. IR Sensitive. Watchdog Security (Manchester) Link to comment Share on other sites More sharing options...
Guest stevey Posted March 29, 2006 Share Posted March 29, 2006 No one longer stocks them, not even norbain or gardiner. So are they still possible to get hold of, if so where? If this is the case, what is an equivilant or better replacement? Link to comment Share on other sites More sharing options...
Doktor Jon Posted March 29, 2006 Share Posted March 29, 2006 Stevey, I'm just curious but are you looking at a 1/2" camera because you are using a 1/2" format lens? If you didn't need the slight increase in wide angle coverage, you could instead consider a very decent 1/3" format camera, with an increased magnification available at the maximum telephoto setting, and probably save a few pennies in the process. Just a suggestion Link to comment Share on other sites More sharing options...
