Zones
Guest jmancs
Guest jmancs
Hey guy's, my galaxy system keeps showing zone as open all time in display zones and it never closes....
the wiring is perfect, its only just started doing it, any idea's ?
J
J
a.. :hmm:
b..using an old exec rio
c..its actually open
d..dc tracking back on circ pair
e..the panel is knackered.. :hmm:
Normally, if the Galaxy says it's open, it's open !
Check the connections in the detector or contact if you are an engineer, check the resistor connections especially and make sure none of the resistor legs are damaged or touching each other.
If you are not an engineer, then you should call one.
Guest jmancs
Hi guy's thanks for the help. anyway i sorted it, the panel is fine now, i did a resistance check on it and it was perfect, all the problem was is the cover "pins did not touch correctly"
Thanks anyway!
J
