Guest Rumble Posted December 12, 2003 Posted December 12, 2003 All is becoming clear ! Is there anyway to tell if its locked? And what is the cost of having the panel unlocked by texecom? I now have the engineers manual and it looks like its all on factory defaults any way ! which explains why the part set is unusable (alarm sounds as soon as you get downstairs) Thanks
FASTCAR Posted December 12, 2003 Posted December 12, 2003 You can't tell if its locked without going into eng prog mode.Looks like you are going to have to find out by crashing it!!.Have a look at the factory defaults and compare them to your system layout, if you think it will work , then you have nothing to loose.Sounds like a good saturday morning job I don't know what Texecom charge to recode , but just think of the hassle factor.
