Guest cliff Posted March 10, 2006 Posted March 10, 2006 Hi I have a Care Tech 1500 and have cut through the cable leading to the outside alarm box,I have re-joined the 6 cables and, done a walk through test and all the detectors work, when I do the Bell Test the outside alarm sounds and flashes, but the indoor alarm does not work, and I cannot set the alam on either full or part. Can anyone help, many thanks if you can.
Guest rjbsec Posted March 10, 2006 Posted March 10, 2006 You need an engineer, anything may have happened - post where you are and someone here may be able to help.
Guest G.J.M Posted March 10, 2006 Posted March 10, 2006 You need an engineer, anything may have happened - post where you are and someone here may be able to help. blown fuse?
Guest cliff Posted March 15, 2006 Posted March 15, 2006 Hi I'm in Bishops Stortford Herts - if anyone can help I'd be very gratefull. Thanks Cliff
Guest cliff Posted March 15, 2006 Posted March 15, 2006 Thanks guy's blown fuse it was - it now works fine.
Guest ALSEC Posted March 15, 2006 Posted March 15, 2006 You just so happened to have a panel fuse with you??
Guest G.J.M Posted March 15, 2006 Posted March 15, 2006 Thanks guy's blown fuse it was - it now works fine. what do i know eh Alsec?
Guest ALSEC Posted March 15, 2006 Posted March 15, 2006 what do i know eh Alsec? by all day long I meant "yes - that would the problem all day long" - I was in agreement with you.. not a bad call for a fire guy!!
