Guest Guest_Steve_* Posted March 12, 2006 Posted March 12, 2006 For some unknown reason the two keypads are beeping every 3 seconds with a flashing Power LED and showing the number "6" in the Zone. I have looked at the user and engineer manual and Im not sure what this relates to. The power to the control panel is fine. Would it be the internal Power supply? Any help or advice would be very much appreciated. Thanks Steve
Guest Posted March 12, 2006 Posted March 12, 2006 Could be the internal power supply, or a fuse. It bleeps every 5 seconds for a powere fail I think. I believe the display will only flash a 6 if that zone has triggered an alarm at some point. Pressing reset should clear any alarm activation displays but the power problem could require some further investigation. Has this system ever been serviced? Chances are it's about to fall over for good.
bellman Posted March 12, 2006 Posted March 12, 2006 Press reset, it's indicating an alarm condition. Regards Bellman Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
Guest Guest_steve_* Posted March 12, 2006 Posted March 12, 2006 Thanks for suggestions. The beeping was going off every three seconds and not the normal 5 seconds to indicate an external power failure. The external keypads would not respond to any resets (nor any key presses). I disconnected the external mains supply and then removed the control panel cover. I then removed the internal battery backup supply for 30 seconds and reconnected it. The control panel immediately went into tamper mode and was reset by entering the engineer code. Since doing a "reset" the system seems to be fine. Perhaps it just needed resetting (I hope). Thanks again for your help and advice. Steve
Guest Posted March 12, 2006 Posted March 12, 2006 Guest_steve_* said: Perhaps it just needed resetting (I hope). Probably needs servicing\replacing but whatever. Obviously your way is cheaper.
