Lens Filter Set Up Kit
Guest The Installer
always used a grade 8 welding glass without a problem, grade 9's are laminated making the image look a little fuzzy
You could try a glass manufacture, ask for some samples of the darker types of glass.
Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
Guest The Installer
alternatively focus them at night and wait for the big ir lamp in the sky the next morning :joker:
We use the computar set, expensive but all you really need although most night/day are so goo they dont need much adjustment if set up ok in the day
PG Security Systems
Somerset
SSAIB Certificate of Merit Installers.
www.pgsecurity.co.uk
Guest ALSEC
I knew a guy who used to use the purple wrapper from chewy toffees..
Hello All,
Looking for a Lens Filter Set Up Kit....I spoke to No Brains but they seem intent on trying to rob me!!
Anyone got any ideas??
Cheerio
Rich
Mate, you can buy your Neutral Density filters, but after ten years of doing town centres and dropping them from the top of poles, trust me when I say, welding glass will do just fine. :P
(50p from machinemart!)
I went up into the attic...I found a Stradavarius & a Picasso. Unfortunately.....
Stradavarius couldn't paint, and Picasso made a shocking fiddle.
My Facebook page...http://www.facebook.com/home.php#/profile.php?id=1279556853&ref=name
