Russ Posted March 14, 2006 Posted March 14, 2006 I have a problem whereby my DVR has locked itself up. I have never put a password in, nor has my customer. I've tried the keylock and just enter combo, and every other normal factory default combo i.e. **** I've also spoken to LJD and they asked me to try a combination of buttons which has not worked either. Anyone have any ideas?
C.S TEK. Posted March 14, 2006 Posted March 14, 2006 I have a problem whereby my DVR has locked itself up.I have never put a password in, nor has my customer. I've tried the keylock and just enter combo, and every other normal factory default combo i.e. **** I've also spoken to LJD and they asked me to try a combination of buttons which has not worked either. Anyone have any ideas? Dont you normaly just press enter when it asks for password. Dont type any number. Chris Trade Member As Mr Kingswood said "Dont forget the 6 P's when installing.....Proper Preperation Prevents P*** Poor Performance!!!" John Kingswood(alais Nobby), Paul Earl Ltd 1985-2006
morph Posted March 14, 2006 Posted March 14, 2006 I've also spoken to LJD and they asked me to try a combination of buttons which has not worked either. If Ljd can't help you mate, I doubt anyone else will. Get LJD to change it.
Ard Disk Posted March 14, 2006 Posted March 14, 2006 Sounds like an Ard Disk failure. If you power down the mains, and on pwering up it goes through part of its boot routine and then siezes -it probably cannot initialise the HD As Alarmguard says, get it replaced - quick while they've got stock:-) Covering Avon & Somerset, Devon & Cornwall www.Blanchard Fire & Security.co.uk NSI Gold
Guest The Installer Posted March 14, 2006 Posted March 14, 2006 is it currently being displayed on a pc via lan or is it a simplex unit as it may not allow you access the menu when its being viewed on network or whilst recording - just a thought
Guest CCTV_SUPPORT Posted March 17, 2006 Posted March 17, 2006 The JPEG2000 DVRs I have seen to get out of Keylock, you do the following: Hold down the Lock button for a few seconds, it will tehn ask for passwords, THe default password is usually blank, so just hit enter. What model was the DVR?
Guest Posted March 17, 2006 Posted March 17, 2006 ...nor has my customer.... they have never done anything if they broke something or forgot the password!! it is just to avoid paying!
Guest fluke Posted May 9, 2006 Posted May 9, 2006 Some of the LJD DVRs have a passcode of****and then enter! This may help?
arfur mo Posted May 9, 2006 Posted May 9, 2006 not sure we should have these tips in the public zone folks circumventing data protection act and all that jaz regs alan If you think education is difficult, try being stupid!!!!
Guest TSi technologies ltd Posted September 13, 2006 Posted September 13, 2006 I have a problem whereby my DVR has locked itself up.I have never put a password in, nor has my customer. I've tried the keylock and just enter combo, and every other normal factory default combo i.e. **** I've also spoken to LJD and they asked me to try a combination of buttons which has not worked either. Anyone have any ideas? hi russ we are tsi technologies and would like to help you with your problem if it is still trublling you its very easy one of my colleuges would be more than happy to talk you through it give our tech help line a call 01952 204422
