Initail Shorrock Alarm
borris
Bit of a vague one this, but I am going to a site soon that has an Initial alarm in it. I have been told that it was only built for Initial but how true this is I don't know.
The alarm has a remote keypad of about 20x10 c, metal case with membrane keys. There is a lcd display about 5x3 cm. It has the zone numbers on the display in rows of 4 or 5, the display is like the modes on a calculator(when it says deg, rad etc.). There are no other markings on the alarm other than "Initial". I am going to try and get a photo but just in case this sounds familiar to anyone...
cheers
initial took over securicor which used to have a panel called a valiant built for them. its a big grey box with blue keypad to what i can remember.never really got head around them as didnt stay with initial very long, do remember though that i got issued a molex connector type gun to connect cables into pirs.
That sounds like the shorrock 1500 or the 2000 does it have a keyhole near the buttons??? :ph34r:
Quote of the day: A good friend will bail you out of jail but a true friend will be sitting next to you saying damn we fcuked up!!!
management treat us like mushrooms!! keep us in the dark and feed us bullsiht!!!
Hi
Went to have a quick look and it says in very small letters "Shorrock 1600 Series". If anyone has any info, as I think it will still have Shorrocks code in it so I may have to crash it.
Thanks again.
Check your email Borris, I`ve sent you what information i have.
Hope it helps.
  • 2 weeks later...
Guest HomeSecurityServicesUK
Boris email me I was with Initial (shorrocks) if it is a 1600 it will be a white blank end station and a white plastic rkp and an lcd display.If the box is a olive colour with the keypad on board it will be a 2000 series or if its white with the rkp on board it will be a 2100.also the 2000 and 2100 have a lockable front.
