Guest nickw1969 Posted March 17, 2006 Posted March 17, 2006 Hi - Sorry if I have posted this in the wrong place. I have an Accenta mini 8 alarm which I didnt turn off in time a couple of days ago - The alarm was sounding only for a couple seconds before I entered the code, but since then I cant seem to do anything with it. If I enter te code nothing happens - no beeps or anything. The day light is off and the power light is on. Can anyone tell me what I have to do to reset it? The alarm was in te house when I moved in and I dont have a manual - Also, can I ask how to change the code? The code is the same as when the last home owner lived in my house and Id obviously like to change it. Thanks Nick
Guest Posted March 17, 2006 Posted March 17, 2006 I dont have a manual You do now. Accenta_8_Mini_User_GUIDE.pdf
Guest nickw1969 Posted March 17, 2006 Posted March 17, 2006 You do now. Accenta_8_Mini_User_GUIDE.pdf Thanks guys - hopefully i'll get it sorted out now
Guest Tasp Posted March 19, 2006 Posted March 19, 2006 It's probably got a tamper, these things won't do anything if a tamper is active, they even appear to have locked up. Clear the tamper then press Reset.
