Guest Noffo Posted March 18, 2006 Posted March 18, 2006 Hi Veritas 8C Panel Can anyone help me? My Alarm worked perfectly well until this afternoon.Coming into the house we where not greeted by the usual alarm tones and i thought the wife just hadnt set the alarm but after thirty seconds the alarm bell sounded and was easily switched off by enetering the code but all keypad tones of gone as well as any entry/exit internal sound. Could anybody advise the likely cause or is it time for a new panel
bellman Posted March 18, 2006 Posted March 18, 2006 Probably blown a fuse, when was it last serviced? Service Engineer and all round nice bloke ) The views above are mine and NOT those of my employer.
antinode Posted March 18, 2006 Posted March 18, 2006 Agreed, it sounds like a fuse problem. The 8C's speaker fuse is shared by the AUX supply, so if that is the case, your movement sensors would'nt be lighting up either. Does a little red light come on when you walk past them? Have you had any carpets layed/done any DIY recently between now and the last time you used the alarm? I asume the alarm was making the relevant exit tone when the system was set? Either way, it does need looking at by a professional intruder alarm engineer. Trade Member
Guest Noffo Posted March 18, 2006 Posted March 18, 2006 Agreed, it sounds like a fuse problem. The 8C's speaker fuse is shared by the AUX supply, so if that is the case, your movement sensors would'nt be lighting up either. Does a little red light come on when you walk past them? Have you had any carpets layed/done any DIY recently between now and the last time you used the alarm? I asume the alarm was making the relevant exit tone when the system was set? Either way, it does need looking at by a professional intruder alarm engineer. Thanks for getting back to me, I have checked the fuses on the PCB and they are fine,all PIR's are working and lighting up ok.
gooner31 Posted March 18, 2006 Posted March 18, 2006 could possibly be the entry door contact is faulty or the reed is sticking might be worth replacing the door contact. pete ................. Any comments/opinions posted are my own and not that of my employers.
Monteey Posted March 18, 2006 Posted March 18, 2006 could possibly be the entry door contact is faulty or the reed is sticking might be worth replacing the door contact. Thas what i was thinking although doesnt explain the lack of keypad tones Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest Noffo Posted March 18, 2006 Posted March 18, 2006 I have no door contacts,the system is just run off PIR's. The Alarm does seem to work okay,but no keypad tones or internal sounds.
FASTCAR Posted March 18, 2006 Posted March 18, 2006 Inside the panel , attached to the terminals marked SPKR or similar (white wires attached) sometimes go open circuit. Dont go in there with the mains on..or better still get a qualified person. Regards.
