Guest HarryK Posted March 21, 2006 Posted March 21, 2006 David Thorpe said: Ok I found it!To exit engineer mode press esc until engineer mode is displayed, then enter the engineer code and press esc once, then it will go back to normal mode. When in Engineer mode tamper alarms will not register so it is important to get it back to normal. Bingo...tried this and it did the job... To get rid of the funny $$ signs ( inverted dollar signs ) and to stop the sensor id'd from displaying when active I pressed the "*" and "#" key simultaneously...not sure what this does but i got my date / time settings back....
Guest Posted March 21, 2006 Posted March 21, 2006 HarryK said: Bingo...tried this and it did the job...To get rid of the funny $$ signs ( inverted dollar signs ) and to stop the sensor id'd from displaying when active I pressed the "*" and "#" key simultaneously...not sure what this does but i got my date / time settings back.... it shows open zones when in engineer mode...you can also enable it on the 60/500 it show which groups are set or unset without putting a code in.....
