Analogx Proxy Setup
colin32
So you must already have 2 NIC cards then if PC1 is cnnected to the modem and PC2 simultaneously?
Easiest way, buy a router. Cheapest way, fit another NIC on PC1.
No, it's either/ or at the moment. Sorry if I wasn't clear about that. I will fit a second NIC for now.
What spec of router would I need.
Thanks for your input.
colin
Er, lol? No wonder it won't work if you can't have them both plugged in at the same time, it's what's called a physical impossibility.
Well you could use a hub/switch of course to save installing the 2nd NIC......
But then you might as well get a router anyway.
All roads lead to using a router and ditching the proxy. You know it makes sense :!:
Problem with that is PC1 will have a WAN address from the CM which will be most likely be stuck in its own subnet thus meaning you'd need a second interface for any other PC's to share this with.
*QFA!
Thanks guys - have managed to source a D-Link DI-604 cable router for
I wasn't really serious about that idea - couldn't you tell! :P
You can never be too careful!
