Guest kin Posted March 27, 2006 Posted March 27, 2006 on the key pad lcd screen message displayed ( dc/fuse fail ) and also power led green light flashing rapidly. i checked all fuses they are all fine. can anybody tell me whats wrong with the system. is a possible to set this system to fectory defult setting thanks all
Monteey Posted March 27, 2006 Posted March 27, 2006 Fella, look at the replies you got from your previous topic, you need to contact an expert as your system clearly needs some attention. Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
morph Posted March 27, 2006 Posted March 27, 2006 You first asked that engineer reset is required. The clue is in the display, What have you tried since you last asked? Clearly you are out of your depth, call an engineer before you do more damge to the panel or yourself. Yes the system can be defaulted by an engineer, we wont be able tell you how on these forums.
