Guest Joe D Posted March 28, 2006 Posted March 28, 2006 I have got a sounder it is a lyntek twin piezo unit and would use it for a internal sounder it is also known as a sound bomb would ot be possible for my installer to connect this to my Optima Compact G3 panel the only sounders i have got is the one built in the panel and the external sounder which is a aztec 1000 bell box made by kinetic sounders as i dont know what current consumption the external sounder takes i know that the lyntec is 95ma current draw. the only problem is i dont know what my panel max ma current consuption is for the sounders. Also the lyntek sounder has only got two short wires a red and a black how would my installer connect this to the panel?
FASTCAR Posted March 28, 2006 Posted March 28, 2006 There shouldnt be a problem adding a sound bomb, but your installer should check the current to be on the safe side.He would connect red to 12v+ and black to SW-ve. Regards.
Adi Posted March 28, 2006 Posted March 28, 2006 Or bell + and bell trigger. I really can't be ar**** with it anymore.
kka Posted March 28, 2006 Posted March 28, 2006 D = +Ve supply (12V) red wire B = -Ve Sounder trigger black wire your installer should beware of mains inside the control panel, always isolate before carring out any alterations. he / she should already know this, it is good practise. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
