Optima Xl6
Guest Peter Mansion
Guest Peter Mansion
Returned home the other day to find that all of the LED's were lit on our Optima XL6 Control Panel. Cut the mains supply and re-connected. Now only the power light is lit but the keypad is unresponsive. Any ideas?
Thanks, Pete
Thanks, Pete
may i ask what you mean by unresponsive. does it not bleep when you push the keys ?, or will it not accept your old code?.
Guest Peter Mansion
Thanks for your quick reples.
Yep, doesn't beep when keys pressed. Keypad back-light is on. Battery hasn't been replaced for many years.
Pete
agree time for a service.. :)
yes.. if a tamper or PA fault is present on the system, it will go to lockout condition (showing the appropriate indication). the keypad will not produce any audible responses and the system will not operate until the fault has being found and rectified.
quoted ' now only the power light is lit '
Thanks, Pete
Dead battery, panel has crashed (common fault with Optima panel)
As RJB says
A full power-off restart may rectify the immediate problem but I would strongly advise a service call.
Guest Peter Mansion
Engineer visited today. New battery required - can't complain the old one had been in there 10 years.
Thanks everyone.
Pete
